1 - 1 of 1 Posts
BEEN GIVEN AWAY - NO LONGER AVAILABLE
I removed all the OEM cable winder window lift system from the right side of my 88 quad and replaced it with a retrofit lift system. The old OEM system is complete and works after a fashion. It will lift the window (with a little human help), and lower the window by itself. I am guessing that the thing needs a new lift motor which costs about $60.
When you install one of these retrofit lift systems you remove everything in the door casing and reuse only the window glass. So this old system is 100% complete. It is yours if you want it for the cost of shipping only.
Robert Hill in Memphis TN contact [email protected]
1 - 1 of 1 Posts
