1 - 17 of 17 Posts
· Premium Member
Cleaning out the garage. I will be adding to the list as I get the parts down. Send me a message if you don't see the item you need. Send me a message for info on parts listed.
S3 rear spoiler 3 pieces
S3 dash knee bolster
S3 rear console section
S3 rear parcel shelf metal luggage bar
GTV mechanical door mechanism
Trailing arms
S2-3-4 trunk torsion bars
S2-3 ZF steering box
S4 steering box and pump
GTV door threshold strips with Alfa script
Radiators...message for years
S/S trim pieces GTV and Spiders...various years... mostly window
S2 Personal steering wheel
S4 steering wheel with air bag and controller
S2-3 radiator fan shroud
Radiator fan 1300-1600, 1750-2000
Upper console frame S2-3
74 GTV grille piece
GTV vent window frames "
67 Spider front bumpers
A/C units unders dash S3-4
Mikuni 40 mm Side draft carburetors...ran great on a Spider track setup
Added. 8/28/20
Koni classic red
GTV 4 bolt wishbone
S2 tachometer
Heater motors
Wiper motors
S2-3 seat rails
S2 side marker lights
S3 fuse box
S2 seat belts
S4 monopod
S3-4 manifolds
Front hubs 105-115
Starters
Wheel jacks S2
Are you saying that you got these parts from someone floating down the river on a raft? .. :whistle:
Reactions: RenaissanceMan
Trailing arms
74 GTV grille piece
You wouldn't happen to have the right side wind wing mechanism would you? Didn't see it on your list but thought I'd ask. Thanks Tim
· Premium Member
I'm in need of S2 seat belts. Are they available for the pickin"?
I'll check back. can you pm a pic or post?
· Premium Member
I accept your offer for the S2 seat belts, thank you
Greg
I'll send info for billing
· Administrator
Your rafters are MUCH newer than mine..
· Premium Member
Discussion Starter · #13 ·
1 - 17 of 17 Posts
