Just purchased a PP hardtop with the following problems:
1. Contact cement did not hold on the lower seal, it turns like rubber and rubs off. It looked like the front seal was too thick, so I pulled off the outer one. It left a coating of contact cement that I just pulled off very easily. Also, Both sides were loose and the center. The complete seal would come off very easily.
2. The fastener clips for the front are mounted straight with the top (top front clamps missing - trying to use ones from rag top). Won't work. The rag top has an angle where they mount, would guess @ about 70 degrees.
3. Does the PP utilize rear guides like the Quad, this doesn't have any?
Any Suggestions. Will check it on some of the forums, maybe they can enlighten.
FYI: I have used the "the 3M super trim adhesive" for years. It's not the best I guess, but I couldn't find any better.
