My mechanic and I looked into the electric power steering but came to conclusion that the entire steering system of the 2600 Sprint was so antiquated that my mechanic came up with what we hope is a better solution. He replace everything from the factory with a modern hydraulically powered rack and pinion unit. Since the car is apart for other upgrades, we haven't had a chance to drive it yet but knowing his expertise and confidence that it will work, there should be no problems. The truth is that the brakes, shock absorbers, springs and rims are all being upgraded but no of the changes are readily visible when you look at the car. For example the rims will be 16" instead of 400 mm, a difference of 1/4" in diameter, which is hard to spot and they will be 1" wider and made from aluminum but they will look just the same as the factory steel rims and use the same hubcaps. This gives the car a bit lighter parts but permits the use of a very large range of modern tires. The replacement disc brakes are vented, slotted and drilled, suitable, if required, for track days. Even the vacuum booster for the brakes has been changed and the brakes now are piped for dual circuits which wasn't available from the factory but adds a great deal of safety to the car. Can you see the changes when standing and looking at the car, no, but they make for a better car to drive. The same is true for little things light replacing the old incandescent headlight bulbs with LED units. When you look at the headlights you only see the factory units but when you turn them on at night you get superior lighting. All this is not being done to produce a concours car but to result in a car that my daughter will use regularly and enjoy.
