push in slightly while turning
If you are referring to the side marker lamps placed in the front bumper just ahead of the wheel wells, the white bulb holder has two slots that slide down over two pins extending out from the cylindrical sleeve of the fixture.
To remove the bulb holder, you have to push in slightly while twisting the holder counter-clockwise. I think there is a spring under the rubber washer in the base of the bulb holder that keeps pressure on the fixture pins when the holder is engaged, hence the need to push down on the bulb holder a bit while unscrewing it.
Perhaps some of these photos will help you visualize the connection so you don't break any of the pieces while trying to remove the holder.
