1 - 16 of 16 Posts
Anyone in California interested in Panasport wheels?
Thinking $1500 for all four with good tires.
Berkeley, California.
Prefer not to ship..
**Comes with Alfa center caps and Alfa valve stem covers.
FYI: Rim size is stamped on outer rim. (Sample:stamped 6JJ15= 6"x15")
Hope this helps.
Cheers, Jon
Offset measurement is important too. It should be stamped somewhere on the rim. They typically label it ET. If it's not there, if you know the width, you can measure the backspace and then subtract half of the width from the backspace.
Whats the date code on the tires? 7" wide?
This I believe it two questions. There should be a date code associated with the DOT number on the rubber. This will let everyone know how old the tires actually are. The second question is about the rim.
Correct me if I'm wrong.
1 - 16 of 16 Posts
