At least I hope. My car has not technically overheated, but when it gets to a little bit above 200 degrees, it starts releasing radiator fluid via the overflow tube. It has gotten to the point that I cannot take the car out if there is a chance of being in a long line of stopped cars along the highway or through town. After many checks with my mechanic including multiple resistor checks, replacing radiator fan bearings, cleaning contacts, system pressure checks, etc., the car was still doing its thing of not holding steady at 195 degrees.
My latest complaint was that the radiator fan appears to cycle off at about 195 to 200 degrees. Something must be telling the fan to shut off at that high temperature. His latest idea was to deactivate the fan sensor that is at the bottom of the radiator (the "coolest" point) and install an adjustable aftermarket sensor near the top where the water enters the radiator from the engine. That would maybe turn the fan on sooner. He purchased an adjustable radiator fan switch that will do the job and the plan was to do the swap.
When I show up on Saturday to drop off the car, he shows me a page from the Centerline catalog where they sell an identical part. They state that "The radiator-fan thermoswitch for the 164 is set for 210°F, right on the edge of overheating. This is too close for comfort! Our adjustable thermoswitch will turn the fan on when you want, giving you a larger margin for safety. We suggest approximately 185°F."
Wow, that is exactly what was happening on my car. The fan was cutting out when the temperature was way too hot. I take it most cars have already had this taken care of? I have never heard of this fix and wanted to pass it along to others with LS's who may be having similar heating issues.
I will let you know how things turn out later on this week.
Thanks everyone and cheers,
Jeff
Dallas, Texas
1994 LS
Jeff
Dallas, Texas
1994 LS
