I'm in the process of restoring the interior of my 84 Spider and would like to know what radio was originally installed. The existing JVC radio/cassette player certainly doesn't look original, or at least I hope not.
the radios were invariably dealer installed (cars came with a blanking plate for the radio cut out)........so anything of the period......JVC or Clarion radio/cassette sounds about right from what I've seen (by the 80's they usually had the alfa badge or script name on them)
this for example is a Clarion 6350 from an 85 seen on an old BB post:
It appears that someone has modified the openings to accept a larger format radio/cassette (lots of rough file marks). Do you know if the original dash was cut by the factory to some radio format and then covered with a blanking plate?
yes
...as this original brochure from an 80 spider shows
http://www.alfabb.com/bb/forums/747871-post5.html
Your spider would have had (I believe) this type of radio blank, slightly different shape, which went right up to the S4 spiders, like here:
http://www.alfabb.com/bb/forums/alfa-romeo-parts-sale-wanted/327153-late-spider-s3-s4-radio-blanking-plate.html
if you were lucky, the dealer would have put the plate in the glove box when he fitted the radio, but most, unfortunately, were just chucked away......
Thanks Dom
That is exactly the information that I was looking for. I'm convinced that the radio in the car is not original so in the trash it goes. Appreciate your help
If it works, put it on EBAY. All radios were a dealer installed option. You would have a hard time finding a factory radio that works...after all a radio that is over 30 years old might not be worth anything..except as an anchor for a rubber duck in the bathtub...
My '85 came with a generic am/fm cassette. Don't know if it was dealer or PO installed, but it was a bit of a hack job. It was the old post mount style, i.e., the volume and tuner posts were threaded for a nut that held the radio in place. There was also some metal bracing for the radio body inside the dash. I replaced it with a modern mount Blaupunkt am/fm/cd with two knobs so it looks somewhat period correct.
