Well, my good old BFG 195-65-15 Touring T/A HR4 tires have come to the end of their useful life. At least two of them have and after finding two nails in the two left side tires today which when removed promptly allow them to go flat on one side only with the weight of my 164 on them. Bummer on July 3.
Had one booted and plugged and plugging other one to hold car up out of the dirt until new tires arrive so will have to suffer through and drive Quik Silver with it's Pep boys Futura 205-60-15 "performance" tires on it.
Anyhow did some www.tirerack.com , BJ Wholesale, Sam's Club and BFG web site research
http://www.bfgoodrichtires.com/bfgapp/catalog/index.jsp
http://www.bfgoodrichtires.com/bfg/productIdSubmit.do
http://www.bfgoodrichtires.com/catalog/passenger-car/6.html
http://www.bfgoodrichtires.com/overview/traction-t-a/2136.html
I decided to order a set of BFG T/A Traction 91H tires with UTQG rating 440 AA A rating as HR4s were 400 A A and a good tire for the era. Hopefully these replacements will be good choice both in the wet and dry.
Size Treadwear Traction Temperature
195/65R15 440 AA A
Tire Size 195/65R15 Service Rating 91H
Description Sidewall RBL
MSPN 62291 Rim Width Range (inches) 5.5 - 7
Section Width on Measuring Rim Width Overall 7.9 on 6
Diameter Tread 25"
Depth 10/32
(in/32nds)
Revs/Mile 832 at 45 mph
Max Load 1356 @ 44psi
For high-speed driving, additional inflation pressure and possibly reduced tire loading and/or upsizing is required. In the absence of specific recommendations by the vehicle manufacturer, use the following guidelines based on those in the European Tyre and Rim Technical Organization Standards Manual.
t For speeds over 160km/h (100 mph), load and inflation must be adjusted according to the table below.
T-Speed Rated Sizes:
Maximum Speed (mph) 100 106 112 118
Inflation Increase (psi) 0.0 1.0 2.0 3.0
Load Capacity (% of max.) 100 100 100 100
H-Speed Rated Sizes:
Maximum Speed (mph) 100 106 112 118 124 130
Inflation Increase (psi) 0.0 1.0 2.0 3.0 4.0 5.0
Load Capacity (% of max.) 100 100 100 100 100 100
V-Speed Rated Sizes:
Maximum Speed (mph) 100 106 112 118 124 130 136 143 149
Inflation Increase (psi) 0 1 2 3 4 5 5 5 5
Load Capacity (% of max) 100 100 100 100 100 100 97 94 91
Hi Steve,
I have BFG Tracton T/A's on my LS and have thought they were great tires. They have held up fairly well althought I have not gotten anywhere near the 40K miles they said they would last. Maybe on a less heavier car they will hold up that long, but not on a 164. Even still, I have gotten almost 3 years out of them and they will be replaced sometime this summer, probably with another set. The tread pattern looks great to me, they are fairly quite on the highway, and have good corning ability. They also seem to still cost just about the same as what I paid for them from Tirerack back in early 2005. . Are you taking the car to the Detroit convention? If so, have a great trip. We can not make it but wish we could. Send over some pictures if you get a chance.
Regards,
Jeff
Dallas, Texas
1994 LS
Can't make convention either this year.
