1 - 5 of 5 Posts
My trunk release felt a bit stiff so I took it out and cleaned it and lubed it, and I found the mechanism had an extra return spring which made it harder for the cable to actuate it. I disconnected that spring and the releasing action is smoother and easier. I suspect the cable will last a bit longer.
I’ve been thinking of an idea lately. When I run errands around town I’m in and out of the trunk a lot. I’ll park the car and lock things in the trunk when I go into a place, then come out and open the trunk again to get things out, etc. I don’t want to over work the cable or the lock on the release, so I was thinking of installing a solenoid to pop the trunk electrically. As I understand it, the spoiler on the back of my ’87 is not metal, I was thinking why not conceal a magnetic reed switch in it and just use a magnet to operate the solenoid. That would make it quick and easy to open.
So I need to search the web and get an inexpensive 12 volt solenoid I can mount in there. These should be a plentiful item. Does any one know a good source?
You're still going to be able to open the trunk when the battery is dead, right?
I have a problem with the reed switch idea. Granted, I haven't seen one of these in a long time, so my concern may be unwarranted, but what is going to keep your trunk from popping open every time you drive over a bump in the road?
Tim
Go check out the solenoid on a 96 and up Maxima, It uses a small solenoid with a short section of cable coming from the pulling end, it has a small ball on the end of the cable to attach to the latch and 2 bolts hold it on. I also agree with Tim, it would most likely be easier to adapt a release button out of the donor car rather than the reed switch in the spoiler:cool:. Good luck and take and post pics if you do it.
That's good thinking Tim, I'm pretty sure the reed switches are able to handle some jostling, but I'll test first. Also, I would attach the solenoid so the trunk cable would still operate.
Thanks for the tips on finding solenoids, Skip and Kevin.
1 - 5 of 5 Posts
