Ok.... Pulled the front head off of the 164 yesterday. Today I pulled the rear head. I undid the nuts and then had a hell of a time getting the head to come off
. It was stuck at the passenger side rear stud.(so I thought!)
Well... with a bit of brute force and some cussing I got it off.
Well...(once again) It came off with the oil pump shaft attached to the gear since I failed to read the manual that I had sitting on my tool box! Removed the shaft from the gear and slid it back down into the oil pump. It slides in and out like a dick in a shirtsleeve
I'm guessing that I'll have to buy a new oil pump unless anyone has any bright ideas. I'm guessing that green sleeve lock-tight won't hold it?
I did discover that it is a lot easier to remove the rear head if you remove the front sub frame bolts, loosen the rear sub frame bolts. before you remove the front bolts you have to remove the core support bolts and then let the sub frame hang on the rear bolts. It makes it so you don't have to remove the false fire wall. (See crappy phone pic) The pic is of the rear cam pulley on the head that i did not have to remove to pull the head.
Paul
Paul
