Slowly getting my Milano back into drivable shape.
I've put about 100 miles on it since this start of the summer. Recently, on a drive, I lost power off idle. History in thread fuel pressure issue?
Things were going well. I parked for about 10 days to pull the driveshaft, replace Giubos, and do some exhaust work (install 3.0 headers, new exhaust sections from Centerline). While it was up, I replaced the fuel filter (first since tank flush, planned work). There was a good amount of crud in the inlet, which was not entirely unanticipated. I had planned on a sacrificial set of filters for the first tank of gas.
I just finished up buttoning everything back up. The car fires up as always when cold (half crank). Little harder when hot (as always). However, it's really struggling to get off idle again, even without load. These symptoms were fuel pressure related the last time they surfaced, so it seems reasonable to assume that might be the case again.
Maybe the pump had enough crud pass through it to diminish performance enough to cause these issues? I inspected the lines prior to the pump today and the fuel coming out is clean.
photos.app.goo.gl
It's hard to see in the video, but timing is factory at +7 ("F" mark on pulley).
Any ideas? Think there is anything there with the pump theory?
Thanks in advance. I'm only this far because of all of you!
New video by Jeff Shinrock
