21 - 40 of 4901 Posts
Discussion Starter #21
Are you loafin'?
Azzurri GTV said:
Nice, but this engine is supposed to go into your 91 spider? A 12 valve BARELY fits in the engine bay how is a 24 valve going to fit? How are you going to mate the 105 tranny to the v6 engine? I know hans in atlanta and Nick in California who are master mechanics and they don't recommend using 105 trannys (to weak). They either use a maserati biturbo trans or a trans from a alfa six.
Azzurri,
All it takes is a properly designed plate adapter/spacer 3/4 around the 105 bell housing just as V6GTJ has shown. Mine is similar to V6GTJ's, except mine is home to the starter as well. As far as the 24 valver fitting in the engine bay? Not a problem;) The tranny? You'd be surprized how robust these trannys are - even in the stock form. But just for added security i've had the entire internals replaced with new components (shafts, syncros, sleves, ect..). As well, all tranny's gears are now forged "close-ratio" gears which have been lightened and hard shot peened for even extra strength. No problems here as well. I've spoken with Nick awhile ago. He said that as long as the tranny is in very good shape - stock even...all would be fine. Dawie has also agreed...
Hey man! Weren't you supposed to stuff sumthin' nasty under your hood?? What's the hold up??:confused: :D
Holla,
streetfame
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
I concur...More Pictures.
streetfame said:
Azzurri,
Holla,
streetfame
i didn't know about the adapter plate. When i asked the same question a while ago i got a diff answer. Good luck with your project and be sure to post lots of pics.
I had a project of my own but time and $$ got me sidetracked, now i'm working on a diff project and i'm trying to get 150hp out of my fiat 500.:D
Are you gonna use megasquirt?
Discussion Starter #25
Rated "XXX"
More Glenwood 3.7L 24V V6 Porn for all you sick puppies...:eek:
Ugggh! Just disgusting! You guys viewing this stuff should be ashamed of yourself...Especially you, John for ...ughhh...god....g-g-gr-groping it:mad:
Wash your hands man!:mad:
Now showing at 4am:
...combustion chambers, new stainless steel racing valves, forged steel chrome molly connecting rod, rod hardware, cams and some porting...
Thanks guys for all your interest. I'll do my best to bring some more images soon and make this thread as interesting and entertaining as possible...
Welcome Msiert - love your spider!! Must run sooo smooth. Great work!!
Holla,
streetfame
Truth of the matter is that the 24 valve heads are more compact - see the threads under Milano/75 - Fit with ABS...!
Also, the 24 valve sits lower in the engine bay than a 12 valve...
As for 450 plus crank horses out of a 3.5 Alfa V6 - maybe on a twin turbo- next you will be telling me that it is a 12 valve too...!? Never on an NA Alfa block. I will personally be doing some candle-licking (and I hate doing that...), on the day that you see 450 plus naturally aspirated at the crank from one of these motors in 3.5 trim no less!!! Nope - not a chance - at least not for two days in a row - the block pulls and the bearings go as soon as the block cools and stress-releases.
TT - yes - 600-700 hp at the crank currently running in SA cars - see this month's Auto Italia Magazine - our friend Stewart Kidgel's TT 3.45 in the Ultima running just 1 Bar....
Nah - I have been personally involved in 15-plus builds with Dawie now over 2 and a half years (arguably a man who knows where the power is on one of these things) and 300 to 330 for the street at the crank is as good as it gets, 350 to 375 for the track and 400-425 in full-race trim. We saw 301 AT THE WHEELS on Jes' 3.7 and my new motor should throw about 340-350 at the wheels here at sea-level.
Azzurri GTV said:
Streetfame,
Why won't you just install the 2.5 liter V8 from a Montreal? Your going to be doing just as much fabrication anyways so why won't you have fun with the extra 2 cylinders!
http://www.foleyalfa.com.au/Racing_Pic1.htm#top
You're not serious are you? Those engines are works of art, but c'mon they get about 250 hp on a very good day.
streetfame said:
3.5L 24V V6 w/425 HP at the crank. non-aspirated?....Not a chance. Sorry bro. You have been mis-informed.
streetfame
I could happen with alot of upgrades. the Alfa 155TI DTM race car was only a 2.5 and it pulled 450hp and it was a NA engine.
He wasn't talking about a build based on a 14K rpm, 50K Euro DTM motor, he was talking about 450 NA horses from a production, 164 LS (Super), or 156 generation block - no amount of "upgrades" will make that pig fly past the 300-425 NA and 350 to 700hp TT limits...
Its simpoly not in the design.
I did see the printout, 452HP...
This is something of the specs of this 'mistery' car.... It has been around on this forum as well, the owner is sidetracked racing his 156 STW in Dutch trofeo, he has a 155 STW as well.
3.5 V6 24V , slide throttle assy, dry sump, in which the dry sump plate incorporates the lower crankshaft bearings.
Cosworth forged pistons, venolia rods, very specially done heads....
Ir did 452 HP on the bench, then a distri belt snapped. This was a faulty belt, the manufacturer paid up. (it was supposed to have an arrow on it pointing direction, not having them, the engine guy, whom I know and he builds really the VERY BEST installed them as unidirectional. )
The maufacturer said you should have the arrow point in the right direction! What arrow? etc...
Other specs: Hewland 6 speed sequential G/box, launch control, etc, for 550 maranello, carbon glued driveshaft, etc etc. Over 150000 euro sunk in the car already.... (over $200000,-) and not finished yet...
believe the 452 HP... once on the track, it will be awesome..
Based on a genuine IMSA 75...
but hey, lets not get sidetracked, this is a cool project as well!
more pics!!!
Azzurri GTV said:
250hp stock but thay can be modified for more power.
I don't think much. That guy in Austrailia who used to race a GTA with one was only getting 240 out of his race-prepped 2.5.
Are the heads modded like the bikes I have seen with smaller ports to get better pumping as opposed to pure flow?
http://mototuneusa.com/thanx.htm
wow, really excited to see how this works out and that you're keeping it all alfa!
can't wait for the finished product and to see if you can keep all the power to the ground and launch!
any chance you can share your budget? PM me if you don't want it public and don't mind sharing. I'd love to do this to my spider, but wondering the $$ range...
thanks
streetfame said:
.... Hey Johnny, You gotta post up here that shot with those pimpin' yellow shoes. Here, i've got a pair i've only worn 5 times in three years cause they're so fly!! Won't even think of driving with them. Those pedels would mash up the white top "quick-fast":eek: So, quit readin' this and post that pic:D
streetfame
...funny guy...:mad:
You mean these; :eek: :D :cool:
Puma - Ferraris - Nordstroms - they had red too - maybe one pair each and mix and match them - one red and one yellow...!:rolleyes: :eek: :D
Discussion Starter #37 (Edited)
Demon's Heart Completed.
Engine is now being tested, tuned and maped. Here are some details of the build:
3.7 litre specification including 100mm Ross Racing aluminium-alloy pistons, custom forged steel tapered wrist pins and double retainers, Total Seal Gapless/Standard Competition ring-set, forged, chrome-molly steel connecting rods from Pauter Machine
Brand-new, long-stroke, 3.2 litre 156/147 GTA crank and bearings.
Prepare block; including over-bore to receive brand new 120mm OD steel liners
Heads ported to proprietary street/track performance specification, custom Group 1 cams with proprietary Group 1 valve-seat profile, brand new valve guides, brand new valve-stem seals, brand new engine gasket-set, brand new timing belt idler pulleys, belt-tensioner and belt.
I supplied John and Dawie with my flywheel and pulley (pulley was then converted to 60-2) and balanced with entire assembly.
At this moment, engine is being run in a test car for tuning, heat/freeze cycle and being maped. Won't be long now....:D :D :D
GoldCloverLeaf - You've got jokes, guy!:D But sorry man! You're about to be blinded once again!:D
Johnny - Thanks for the hook-up!:D :rolleyes:
Stay tuned all. A LOT more to follow...:eek:
streetfame
...when is the last time that you saw one of those motors being driven daily...? Get real. How much to build a factory DTM motor? Yeah, the 2.5 made 450 at 14K rpm and a complete rebuild between each race...
We are talking about a street-able motor here - not THE MOST EXTREME ELIMINATION knock-out pipe-dream whatever story! Sorry bud, but let's discuss this within context of what the man IS doing, not what he SHOULD HAVE COULD HAVE DONE....
No flame-roasting here - just reality...
Dawie made his in to 3.3 litres! he even built one with fully-programmable stand-alone engine management system, (yes, a GoTech), coil-packs, full electronic EFI, something like 10.7:1 or 11:1 compression and it still made less than what we make with a mild 3.45 litre 24 valve...
Let's face it - the 2.6 V8 made it in to the Montreal after Alfa Romeo themselves could not build a reliable strong motor from it... After it was detuned, it was a huge success....
One small correction here Michael - the one 24 valve motor in the pics above with the valve covers off is actually my 3.45 litre that is going in my street 164 LS with a 6-speed close-ratio GTA gearbox... :eek: Sorry bud - the shots all came in in the same email - my fault!
Yours does not have the spacer plates at the bottom there like in these pics, but rather you have those two blocks of 6 individual throttle-plates! The one with the black covers, chrome intake runners, trumpets and the test tail-housing and test headers bolted to it IS yours... :D
Yours with the intake runners off looks just like my 3.7 seen here:
http://www.alfabb.com/bb/forums/showthread.php?t=19322&page=2
