THIS IS THE OMEGA MOTORSPORTS RACE CAR FOR SALE BY UWE BACKER.
DYNO TESTED 250hp AT THE CRANK (193hp AT THE REAR WHEELS), 180lb/ft TORQUE.
TEST SHEET AVAILABLE BY REQUEST.
ENGINE:
BUILT, BLUEPRINTED, AND BALANCED 2.0 EURO TWIN SPARK MOTOR (BORED TO 2.3).
HIGH COMPRESSION PISTONS, CUSTOM RODS, HIGH DURATION CAMS, BIG VALVES, STROKED AND LIGHTENED CRANK, ALUMINUM FLYWHEEL, COPPER HEAD GASKET.
INSTEAD OF A LOWER CHAIN, CUSTOM GEAR DRIVEN LOWER TIMING INSTALLED.
PROGRAMABLE FUEL INJECTION WITH INDIVIDUAL THROTTLE BODIES AND DISTRIBUTORLESS ELECTRONIC IGNITION.
GEAR BOX:
ALL NEW LIGHTENED GEARS.
ALL NEW SYNCHROS.
4-PADS RACING CERAMIC CLUTCH.
BRAKES:
WILWOOD CALIPERS, 4-PISTON FRONT, 2-PISTON REAR.
TILTON PEDALS AND HYDRAULICS.
SUSPENSION:
GTA SWAY BARS, FRONT AND REAR.
CUSTOM PANHARD ROD.
KONI YELLOW SHOCKS, FRONT AND REAR.
EIBACH REAR COIL-OVER SPRINGS.
POLYURETHANE BUSHINGS.
15X9 POWER TECH WHEELS (GERMANY).
OTHER STUFF:
CUSTOM BODY WORK.
CERAMIC COATED HEADERS.
CUSTOM BUILT EXHAUST.
FUEL CELL WITH BUILT-IN FUEL PUMP.
FULL CUSTOM ROLL CAGE.
CUSTOM REMOTE SHIFT LINKAGE.
PLEXIGLASS REAR WINDSHIELD WITH AIR DIFFUSER.
PLEXIGLASS SIDE REAR WINDOWS WITH AIR INLETS.
DRIVER WINDOW NET WITH CUSTOM RELEASE BRACKET.
FIBERGLASS GTV RACING DASHBOARD.
QUICK-RELEASE STEERING HUB.
FULL RACING INSTRUMENTATION.
TWO TEMPERATURE GAUGES, AT RADIATOR AND AT BACK OF THE HEAD.
ALUMINUM RADIATOR.
CUSTOM REAR UNDERBODY AIR DIFFUSER.
ABSOLUTELY ZERO RUST CALIFORNIA CAR.
PRICE OF THIS MEAN TOY IS $25000, OR $15000 WITHOUT ENGINE AND GEAR BOX.
ONLY SERIOUS INQUIRES PLEASE.
CONTACT UWE BACKER AT OMEGA MOTORSPORTS (310)836-3160.
