1 - 9 of 9 Posts
Hi,
I use a 10w40 in my 16v, I’m sure that any good quality oil in this graduation is perfect for your engine.
Personally, I don’t like use additives in the oil.
Best regards
1973 GTV, 1969 GTV, TR4 & 1969 Roadrunner (long gone), 1967 & 1969 Corvettes
:confused:what would be the best oil for 1.7 ie engine and would it be smart to put some aditives like "ceramic power"
Same stuff I think that this guy tried to talk me into buying
I have always liked the Shell Helix range of oils for my Alfa 1.7 8V, among other things they do have great cleaning characteristics, as I am always amazed at how clean the inside of my engine is when I do any significant work.
I used to always use semi synthetic 10W40 grade oil but found small flecks of aluminium (not bearings) at the bottom of the pan after every change. I have since changed to a thicker 15W50 grade shell helix super mineral oil, and the number of flecks in the oil after a change are significantly less. Hence, what Im trying to say is that these engines are by no means young engines anymore and the tolerances were never like what they are today. I think it is best to run a slightly thicker oil than recommended, ie 15W50, as a thicker oil will have a thicker coat on the internal parts and fill the 'gaps' between parts, ie worn areas and larger tolerances and give better protection. Just my two cents.
Also oil change intervals of 5000kms should be stuck to with a good quality filter (of appropriate size) replaced at all oil changes.
I use shell fully synthetic 10w40 as it leaves fewer deposits in engine and effectivley cleans engine as well as ruuning a little cooler.
google synthetics on the web there is a lot of info
There is a myth that fully synthetic in an older engine will strt to seep through seals but I haven't found this on either of my boxer engined beasties.
alfa 33 1.7 ti
Porsche 911-3.2carrera
I use castrol 10w60 sythetic R, but its a new engine too so bit different too. But with my 8v i have to agree with the shell synthetic range they are very good too. Just stay away from those jap lightweight oils :eek::p
Alfa recommend 10W-50. Try and stick to that. 15W-50 good too. If you live in a cold climate, 10W-40 would be good.
Apparently the new SM oil specification specifies greatly less thiosphosphates than the older spec oils. Some owners of older cars are reporting severe valve train damage after running these oils. I don't know if this affects boxers.
I use hpr-10 in my 16v sud, I think it's a semi-syn 10w-50. Does alright nice and smooth, but I get a little bit of seepage past the rings so it blows a cloud in the morning.
1 - 9 of 9 Posts
