1 - 17 of 17 Posts
Came across an oil temperature gauge in the old part bins at an Alfa dealer friend.
It is made by Veglia Borletti and with a temperature range from 50 to 130 degrees Celsius.
I have never seen one of these referenced in the parts catalogues, nor have I ever seen a part number.
It seems to be an original Alfa part rather than aftermarket. It is consistent with 1750 GTV and GT junior gauges of the period.
The chrome bezel shown in the picture is made by Jaeger and machined to fit a 1750GTV wooden dash where the space is limited due to the chrome surround.
The only place where I have seen a picture of this gauge is in Tabucchi's GTA book in the color plates showing a GTAm interior (which incidentally also shows the special GTAm tach).
Anybody have any information, part number, etc. on this part including any vehicle(s) it was originally mounted? Special option? GTAm option?
Hello Alleggerita,
I checked the Competition Reference Handbook and the several Performance Options Catalogs (I to IV) and couldn't find this Veglia Borletti instrument. The homologation papers of the 1750/2000 GTAm also didn't give a clue. Looking through info on the internet, it seems this is regular 105 part with the oil pressure gauge also memtioned and shown.
Ciao, Olaf
Hi Olaf, the one Alleggerita is showing is clearly an oil temperature gauge, not a oil pressure one..
Discussion Starter · #5 ·
Oil temperature was a common gauge on all 102/106/101/early 105 GT.
But oil temp disappeared from late scalino/1750 onward.
The picture I posted is obviously consistent with the other factory installed Veglia Borletti gauges on late scalino 1300 and 1750 GTV. It does not look like generic Veglia Borletti aftermarket.
Additional gauges were commonly installed on 1750GTAm. I have seen the listing/part # for the race tachometer. However, never seen an Alfa part# for any other additional gauges.
The question remains. Anybody seen one installed in a car or ever come across a part #.
One of the upper gauges in this early GTV, might be (I am not sure whether the left gauge is clock or oil pressure indicator, if so the right one is oil temperature) the image you are searching for. Lower ones are fuel and water gauges. Regrettably, the photo is bad angle.
I made one of these....
I took apart an oil pressure housing, and a water temp gauge. I fitted the water temp gauge in the oil pressure housing and created this. So I had a same-looking oil temp gauge..
Had it sent off and mated to a sender unit. Still working perfect 10 years later.
Car not here so do not recall if it went to 120 or 130 degrees.
howdy alleggerita,
thats a cool gauge, where do i find one of these that matches the 1750 gauges? im collection parts for a stepnose track car build sometimes in the near future...
regards
db
GTAm part
I just ran across this photo I made when I sneaked into the Museo's GTAm at Essen when everybody went for a pasta at lunch time.
They used an unbranded veglia water temp gauge in that one..
the museo car appear to have used the zagato silver/black console along with the blacked out trim mixed in with the chrome bezel on the IP. this wasnt out of the ordinary since the racing department just used what was available.
im not an expert on gtams but i reckon there isnt a definitive gtam spec'ed car out side of the first couple made? this is especially true on the interior. seems like guages, seats steering, seats varied. there were multiple mechanical differences too, valve covers, injections of some of the very late autodelta built or modified gtams varied in detail. i recall some even used later 2000 body and parts. anyone remember the fiberglass bumper gtam painted to look like chrome?
I made this for my Giulia a while ago, a combination of an Alfa Instrument housing and a VDO Oil Temp instrument, not difficult to make and looks almost original.
WOW :smile2: this is may car!!!
Anyway, I built the oil thermometer myself; I took the indicators from a 1750 sedan and I put the oil label on the water thermometer and it works very well. I used the radio compartment.
1 - 17 of 17 Posts
