I am in desperate need for a new oil sump pan for my 102 1962 Touring 2000. The one on the car now has a small hole and is pretty corroded and banged up. Even if we somehow can fix the hole I am certain that it will still seep and leave an annoying stain on the otherwise pristine garage floor. I think a leaking sump was probably a factory option included on all 102s but maybe someone out there can tell me where I might find a new one or a good used one or maybe someone has experience repairing them or overhauling them. They seem to be so fragile. Any help will be greatly appreciated and even rewarded.
Push hard and live
The leaks were not an option. Factory standard equipment.
I had a pan once that had been beautifully tig welded around the entire circumference of the intersection between the top and bottom sections.
If you’re diligent, you could strike up a search in Brazil for a pan from the FNM 2300. Beautiful cast aluminum, and they bolt straight on.
Discussion Starter · #5 ·
