1 - 11 of 11 Posts
Is this oil pump pickup for an Alfetta, or Berlina?
1679548
Alfetta again.
Thanks, I thought that one was for the Alfetta.
The Alfetta pump has steel gears and more end play. The Berlina pump has 1 brass gear. Is one better than the other?
Started assembly. Where do these engines typically leak? I want to take particular care in those areas.
1680212
1680213
You might move this to the engines forum. Gordon Raymond can answer oil pump questions.
Thanks Andrew..
G
Do I need a moderator to move this thread to the engine form?
The Berlina oil pump seemed to be in better condition, so I put it in the front cover. It's the one with one brass gear and the correct pickup for the Berlina.
I moved if for you Richard.
G.
Thanks Gordon:)
1 - 11 of 11 Posts
