Hey guys, long time no talk.
Just got the car back from a shop; there was a driveline issue that had to be resolved.
Question though. The oil pressure light flicked on the first time I was driving it, so, naturally, I checked the oil. The car burns some oil, and the oil level was right above minimum. I put two quarts of 10W-40 in it, and it brought it up to about 2/3 level I suppose. I didn't have another quart on hand but I figured it would do for a while. Anyways, the problem didn't come back for a day or so, but now has come back and it continues to stay on (flashing) even while the pedal is depressed. The gauge hovers at around 3 bar at idle (right below the quarter mark) and at cruising speeds (or RPM's, rather) it hovers around 4 bar (middle mark) at about 2800 RPM or so (this is of course with a hot engine). Is the sensor light faulty or am I really having some oil pump problems? Should I go to a 5W-40 oil instead? I believe a synthetic is in there now (not my choice, and yes I was irritated) but if you guys think it is best to get some good regular oil (it'd be great if someone had input on weights and types, please!) then I will do that first.
Just looking out for the little engine. They're so few and far between these days that I can't bear to see mine go!
Thanks again, guys. Always a great help!
