Hi guys
I am in the final stages of a '65 Veloce restoration and have just fired up the rebuilt 1600 Veloce engine for the first time. The oil pressure starts at around 60 psi but rapidly drops off to around 10 or worse. I'm talking within the first minute before the oil has a chance to warm up. Raising the rev's helps a bit but then it tails off again even when running around 2500 rpm. If I turn it off and wait a minute then I get the same thing, 60 psi initially tailing off rapidly. My first thought was that the pump is running out of oil in the Veloce pan but the oil level is topped up to the max mark and the car is level. The symptoms look like the pressure overflow valve is opening and it has also been suggested that a crank plug is missing. I don't have any knowledge of either of these things to know whether they are the likely cause or not.
The rebuild, using many rare NOS parts, was completed two years ago by a renowned Italian Alfa engineer with many years of experience. Regrettably I can't contact him now.
Anyone know what could be happening?
Phil
Phil
