Hello. I noticed something today on the replacement engine I am putting in my 1983 GTV6. The old original engine coming out..had oil pressure feeds going from under the oil pressure gauge sender to the back of the heads. The new engine(from a 1987 Milano I was told) has no such feeds. Was the 1987 2.5 V6 revised to have the heads fed by oil galleries direct from the block to the heads? As you can see in the picture of the new engine...the port of the oil feed is blocked off. And what is the sender on the left? For a idiot oil pressure light? Thanks again for any comments.....from a first time Alfa owner.
