1986 Alfa Quad
RML Distributor NO additional box.
Battery 12.53 at battery posts
11.42 when trying to start
fuel pump fuse next to ECU good
all fuses in dash tested and good (replaced even if it looked funny but tested fine)
Coil brand new BOSCE super blue tested it is with in specs.
Readings at coil with ignition in the start position..
+ side to ground 12+ volts
- side to ground 12+ volts
no spark at plugs...no start....
no joy
So before someone tells me to look at the L-JET diagnostics.... I have and no air leaks and checked all the ground wires...(not meant to be rude to the brain trust)
So to the collective brain trust are there
any additional tests before i pull the dizzy and call Rick and ask him to take a look.
V/R
Chris
no joy
V/R
Chris
