FOR SALE: OEM CARB CONVERSTION KIT FOR 1750 0R 2000. CONVERT YOUR FUEL INJECTION TO CARBS USING OEM PARTS.
2 40 DCOE 32 carbs as used on 1750 and 2000 engines, you re jet if required by your engines state of tune
4 used carb mounts (not shown) but you should buy new ones
1 plenum to support air box, needs top gasket pair
1 Air box with 2 straps, hose for cam cover breather and used air filter
1 drop in thermostat type manifold as used on 1750 and 2000
1 bell crank assembly and 2 rods
1 support strut needing a new rubber bushing (which I might find)
1 gas pedal rod for carbs less pedal unless you need then I can find, with new rubber bushing to be installed
1 cooling water tee needed only depending on your water pump type and hoses
The carbs were disassembled and cleaned decades ago by the guy I got them from and I cannot say more about them.
You will need to buy some gaskets, a low pressure fuel pump and a pressure regulator/filter. All available from Classic Alfa in UK or others.
US$ 1400 plus shipping by UPS I think, plus pay pal commission if any.
thanks for looking
Ken
Gas Tool Font Metalworking hand tool Auto part
Musical instrument Font Gas Metal Flooring
Discussion Starter · #2 ·
More photos.
BTT
Discussion Starter · #4 ·
BTT
