1 - 5 of 5 Posts
I purchased my 89 Graduate 3 months ago; the car has 96k miles and I have been replacing parts and hoses in an effort to make it road worthy. I replaced the O2 sensor with a Bosch 3 wire unit. The PO had used a one wire sensor and I know that CA emissions require 3 wires. So I started the car and it ran for about 5 seconds then the fuse at the fuel pump relay blew. I disconnected the plug with two white wires and the car ran ok but a little rich. What would cause the sensor to blow the fuse? I would really appreciate your help, O wise ones. This was originally a California car that was taken out of state for 10 years.
The two wire connector is the oxygen sensor heater. These can short internally. Unusual in a new sensor, though.
I think the fuse should be 8A...that what you've got? If so, check the resistance between the two wires in that plug on the sensor, see if it's shorted.
If it's good it's probably somewhere around maybe 4-10 ohms? If it's shorted it'll be <1 ohm.
1 - 5 of 5 Posts
