I am sure someone will have more to say but the numbers you show look like ring end gap with the ring in the cylinder at some distance from the top, IIRC 10mm from the top a 0.020" end gap is in spec.
But they could have been overheated and lost their tension.
Check the head for flatness and cylinders should be a couple of thousandths above the block.
Fresh rings and bearings if the cylinders are not scored or have a massive ridge might be all needed.
PS don't break the seal at the bottom of the cylinder to block.
