During installation of a new rebuilt SPICA, I am finding that the tubing from the pump to the injectors does not quite fit the holder brackets. This requires some force to get them in place. Will that hurt anything ?
Background: my car was missing all the brackets that hold the tubing. Since I was pulling the pump for rebuild, Wes recommended locating a set of the brackets, and also replacing the tubing itself since mine may have been vibration-fatigued running all those years with no support brackets.. Got it all from APE, but I have to use some prying to get the tubes into position and into the brackets. Is that Normal ?
note: I'm referring to the brackets that mount to the underside of the manifold and the one on the SPICA's own bracket that holds all four tubes.
Cheers,
Jeff
Cheers,
Jeff
