Just would like to know if this is a 164 part, if so where? It's got a pretty unusual left hand thread. I don't recall seeing it on a 164.
It came with a bunch of parts I got from Ted whose "mechanic" told him he needed, including a belt tensioner I've never seen, a new OEM oil pump because his gage was showing low, etc.
That is not from an Alfa 164. Its from an Alfetta or GTV 6. Its an adjustment bolt for the steering column height.
The 164 uses that style bolt to adjust the steering column, too.
Yup, remember when I completely pulled my steering column apart a few months ago to fix the off-centering of the rack? Well here's a word of advice - DO NOT remove that bolt unless absolutely necessary (which in my case it was not) It's a real MF'er to get back in again.
Steering column adjustment bolt
Yes I thought steering column straight away, removed a million of them, removed and replaced quite a few 164 steering columns Paul, I never recall any problems getting the bolts back in :scared:
