1 - 17 of 17 Posts
hello,
for sale are some NOS parts:
10548.56020.06 1750/2000 spider €10
60726235 Alfetta gtv €50
60728863 Alfetta gtv €50
60726406 Alfetta gtv €100
rubber bumper parts €7,50 each
suspension belts €12,50 a piece
regards,
john
hello,
regards,
john
I’m not familiar with the part numbers
Can you confirm if you have the rubber inserts for the 1970-1972 Alfa Romeo spider?
If so I’ll take one of each side
That part number, 105.48.56.020.06, is for a 1750/2000 Berlina hood release cable, not a Spider.
Push hard and live
Johni,
I don’t have a copy with the new part numbers, only the originals. I am looking for nearly all of the rubber seals for a 2.0 Alfetta GT. Can you describe the rubber body seals you have? If they fit my Alfetta, I will take them.
Thank you!
hello Don,
i checked the numbers and they are for the Alfetta GT (GTV).
they are all for the doors and all in original Alfa plastic.
regards,
john
Push hard and live
I printed the relevant catalog pages last night. I’ll check the fit and contact you later. It’s very late here right now.
thanks!
Push hard and live
Hello Johni,
I'm happy to take the 60726235 and 60728863. I am unable to locate 60726406 in the parts manual. The tab in the rear of the catalog does not list this part number at all.
Can you tell me what it is, and where you found it in a catalog?
Push hard and live
Hello Johni,
I've tried to find the catalog details using both the old/original part number, and the new. There is no inclusion of this number anywhere I can find.
It appears to be a door seal of some sort, in which case I'm happy to have it. If it is a seal for the front or rear window, or the rear hatch, those are the only seals I do not need at the moment. Can you tell what/where it is supposed to fit?
The door, according to the parts book, uses the same seal for left and right. It is part number 60728863. I already want that one. If the 406 part number is an identical part, I'll take it as well. I doubt it is, however, as your part appears to be a single long piece, rather than a closed loop as in the picture below.
The shape could be the rear hatch seal. I don't believe I need that, but I'll look at it in the morning to see the condition.
1623079
Many thanks
Don
Discussion Starter #14
hello Don,
I can tell you that it is nor for the front or rear window and not for the rear hatch too.
it is the door surrounding and I do not believe 28863 and 26406 are the same. I will look at the parts without opening the package.
let you know
Hi Don, John,
FYI, the 60726406 would be the 11610.62124.00 indeed which according to the 1977 rapido catalog is the door rubber, left = right. (I don't know whether it fits later years of course)
Thierry
Push hard and live
I believe the door surround was offered in both all-rubber and felt. Maybe that is the difference.
let’s go ahead with the order, including all three pieces. PM cost as usual.
thanks!
1 - 17 of 17 Posts
