..hitting a curb? distroying our waterpump? that was one tall curb..did you not also distroy your nose of the car and the rad?
The solution is simple, owning an Alfa is not hard at all, sell it. And yes, that was meant as humor. You'd miss all the fun like this of learning from mistakes, although, some of them may be expensive ones. Hopefully, ones you'll never repeat...hitting a curb? distroying our waterpump? that was one tall curb..did you not also distroy your nose of the car and the rad?
Ah, the subtle differences between owning a true sports car and a joe-every-car: no clutch pedal interlock in the starter circut..... (it's never 'I thought it was in neutral' but should always be 'I check that it's in neutral')I thought the car was in neutral but it was in first and I started it and it hit the curb
Did you damage the waterpump or the fan and/or shroud? Your mechanic's estimate of $100 to buy and install a waterpump seems very low (the part alone cost about $90 in the Centerline & IAP catalogs). I'm guessing that the oilpan hit the curb, kicked the running engine upward, and the rotating fan impacted the shroud, breaking one or both of these plastic pieces. Since the fan and shroud are plastic, and since this plastic becomes brittle with age, you may have done yourself a favor to have forced their replacement - having a fan explode on the highway can do more serious damage.
Clutch inter-lock/ignition systems are fine to protect, imo, idiots that don't know how to properly start a manual transmission vehicle, but they are essentially a pain in the rear for anyone that does; and especially when they go out and you can't get the car started. My daughter has been through two of them on her 2004 safety-equipped manual transmission vehicle.Ah, the subtle differences between owning a true sports car and a joe-every-car: no clutch pedal interlock in the starter circut..... (it's never 'I thought it was in neutral' but should always be 'I check that it's in neutral')
On that note, you could prolly scrounge up a clutch interlock off almost any joe-every-car in the junkyard that's been made since the mid 1980's and incorporate it into your system. They look simular to and operate in the same fashion as the brake light switch on the brake pedal. (likely tying right into the ignition switch wires which happen to be just a couple inches away)
I'm curious too:
How did you wreck the waterpump but not the tinwork, the radiator, the oil sump and/or the crank pulley? (they all stick out by a little to a LOT more than the pump)
wow your quite right he just told me 100 for the labor and yes the fan shroud is broken but not the fan itself.... should i just replace it with the waterpump?
I'm also wondering the same thing... The '74 nose has no valance or spoiler. Thus, the sump (and sump guard, if one is installed) is completely exposed. It is very easy to push the engine up or back, if the sump doesn't clear the obstacle enough......I still don't understand how you end up destroying the water pump in the way you described. How did you determine that it needs to be replaced? Do you have any water leak? If so, chances are that your fan poked a hole on the radiator, which could happen when the engine is pushed up (or down in case of sagging engine mounts) excessively and the fan hits the radiator.
I thought your daughter was 15 years old??!!??My daughter has been through two of them on her 2004 safety-equipped manual transmission vehicle.
The one you're referring to with the broken ankle is, she is Pat and my youngest. We had three children together, he had five total; ours was a second family of sorts for him; I am five years older than his oldest son.I thought your daughter was 15 years old??!!??
Yes indeed, that would make you younger than I thought to begin with...Hooray for you!!!More confused than ever now?![]()
Thanks, just proof that you're a newbie to Alfadom and aren't familiar with all the gossip and jokes that Pat and I endured over the years about our relationship, difference in ages, and what miraculous things did happen!!!! Now that we've hijacked this thread, let's see how I can get it back on track....Yes indeed, that would make you younger than I thought to begin with...Hooray for you!!!I was thinking, because of his age, you were in your 70's, but that never added up to having a 15 year old, but you know more miraclous things have happened.
That just goes to show most men work better with older equipmentand they certainly had no smog equipment. How's that?![]()
