So, there is a 14-pin connector that plugs in from the automatic control unit harness (now removed for the conversio to manual) in to the main engine ECU harness (right there to the right of the dash on the passenger-side foot-well side of the center console!)
It has a grey wire with a black stripe coming out of the ECU side and that grey and black wire has to be grounded. That ground completes the circuit for relay number "i 10" located under the dash on the driver-side, by the driver's right knee. The relay has a purple, a black, a grey with black stripe and a red wire coming in to it.
That relay passes power through (on an automatic car any way), to the starter IF the gear selector is in "P" for Park...
Now I had the car fire right up, but it is running rough!
It can only be an ignition-module/coil-pack/injector/injector harness/compression/spark plug problem and I don't have long! (I have to get it running right so that I can go and put it under load to seat the rings...!)
Any suggestions?
1) It has dead cylinders on both banks (looks like about 3 from pulling injector leads while it was running briefly.)
2) It will run with the one ignition module plugged in by itself, but not with the 2nd one plugged in by itself (I guess that this means more dead cylinders on the one bank than on the other...?) They were fine in December when I drove the car down to Texas though!
3) The injector harness checks out fine (noid-light tested all 6 injector tails and we have good pulse to all 6 injectors!)
4) All 6 injectors were reconditioned, but they all sat for 6-7-8 months now - installed in the heads but not being used. Could 2-3 of them start sticking because of sitting for so long after cleaning/reconditioning?
5) Have not checked compression yet - trusting that the motor build is fine - Dawie at Glenwood has done me right to date!
6) Have not checked the coil-packs yet - wouldn't know how at this stage either, but again - these things were fine to begin with - driving the car down here just this last December, it ran smooth.
Any suggestions where to take things to next?
Any suggestions?
