The car is a 77 Alfetta GTV with single point distrbutor. It has a new Bosch coil with internal resitor. Power off the wires at the coil is 11.9 Volts. Power with wires connected to coil with switch on is 10.9 Volts. Power during cranking is 8.5 Volts. The coil - side has two wires, condenser and ground. The + side has a green wire and a black wire (I am unsure of this one). The distrbutor has a new condenser, points and cap. Plug wires are Taylor brand and in good condition. This is my third Alfetta (two GTV's and one sedan). I have never seen this kind of melt down before. Guys, I am in a bad spot. I wanted to take her to the French Italian show at Woodley Park (Van Nuys Ca) today, but she has turned into a bad date. I just need to get some spark out of the coil H/T wire.
Thanks jetsetrj
Thanks jetsetrj
