no power to a/c - 1984 Spider
Tags
a/c fuse
1K views 1 reply 2 participants last post by  papajam
I need help tracing the power supply to the a/c switch. The wiring diagram lists a 20 amp inline fuse with power coming from the ignition switch, brown wire. The only inline fuse I can find is above the fusebox (blade type) using red wires with white stripe that comes from the back of the fusebox. Thanks in advance for any help provided.
#2 ·
Try by the electrical junction block in the engine bay. It's on the left inner fender by the brake master cylinder. There's a bunch of red wires and 2 green wires in it. Alfa used this location to attach a 20A in-line A/C fuse.
There is a 2nd A/C fuse that I thought was in the vicinity of the fusebox.
