Here’s a weird one. My speedo, tach, and clock have no illumination. The headlight/high beam and turn signal indicators in the tach work, just not the green illumination for the actual gauges. My auxiliary gauges are fine and the potentiometer that controls brightness works fine. All the fuses are good, wiring is intact and checked out. Is there a junction or ground wire for just that circuit that might worked loose? Any other ideas? Makes driving after dusk more entertaining than it needs to be. Ha.
