Hi folks, thanks in advance for your sage wisdom about my 82 l-jet spider.
1) removed head for machine work, engine mounts, injector cleaning etc.
2) cleaned starter connections and applied dielectric grease while apart.
3) Upon starting following reassembly I can hear the fuel pumps running but no click from starter relay - nothing. Battery is fully charged, fuses intact, hoses and l-jet connectors appear to be correctly connected.
Anything obvious to check before I remove the intake plenum again and double check that the starter is still properly hooked up? Is there an easier way to check for voltage to starter?
thank you again,
Paul
thank you again,
Paul
