Hi Guys,
I have a 2L rebuilt engine that i have put into my GTV. After many evenings trying to start the engine, and fiddling with carbs, distributor, fuel pump and trying just about everything i broke down and took the car to my Mechanic. We did a compression test and it turns out that 1 and 2 cyclinders have no compression, while 3 and 4 have the proper amount. We took the cam cover off and everything seemed to be on TDC and the lobes facing out. What could be the problem? Cams? bent valves?
I didn't build this engine, so i am not entirely sure if everything was done properly.
