I am awakening a 1750 SPICA motor that has been asleep for twenty years. Rather quickly we were able to get it running but I am not developing power. When I pull the plug wires I get no rpm drop in two and four. I am getting spark. Even so, I have replaced the plugs and the wires but no change. Next I cracked the line at the injector to verify that I was geting fuel - I am. Then I pulled the injector and connected it back on the fuel line to see if I was getting fuel out of it - I am. (Pulled the plugs and #2  were wet - the others were perfect). Then I did a dry compression test. All cylinders came in at between 170 and 175. Not super but nice and consistent. I don't have a set up to do a leak down test but that seems to be the next step. A flashlight down the spark plug hole didn't reveal anything unusual.
There are no unusual noises that would lead me to think that I've got a valve floating around. In fact, it idles quite nicely and even revs freeely without under load.
I can't think of anything else to do other than to walk back through eveything again. Anybody got any suggestions? If I can't find anything wrong my next step will be to pull the head. I really hate to do this because the motor appears to be nice and tight, no leaks, no smoke out the tail pipe.
