I have positioned the etch mark on the flywheel of my '88 Spider to the 12:00 position, with crankshaft at TDC, but no.1 cylinder does not fire properly.
At the 12:00 position, the magnetic pin on the flywheel is at approximately the 2:00 position, about 60 degrees away from the sensor on bell housing, at approximately the 4:00 position. Could this be causing the problem with no. 1 cylinder not firing properly?
What is the proper position of magnetic relative to the bottom sensor on the bell housing?
Do I have the flywheel aligned properly and something else is causing the problem.
Thank you.
Thank you.
