as i play with nissans aswell as alfas ive had the idea of fitting the ecu / sensors and loom from a nissan ca18 onto my twinspark engine.
the reason for this is i want a programmable efi system for a low cost. and can have a NIStune ecu installed or the nissan ecu re-mapped and the loom re-arranged to suit the alfa engine very easly and cheaply.
there is 2 big issues to making the nissan ecu/loom work with the TS:
first would be the need for 4 more coil packs:
im wondering... is it possible to wire a extra coil pack into the nissan loom (in series or parrallel??) for each coil, making the loom have 8 coil packs? and the ecu thinking it is firing just one but infact its firing 2 for each cylinder? i think this could work, aslong as the coil packs fire at the same time and there is no voltage drop between them, i cant see why not?
next would would be mounting the exhaust driven CAS, but as the TS uses an exhaust driven distributor it can be done, the dizzy can be removed, a shaft/adapter/seal made to go between the alfa camshaft, alfa head and nissan CAS, then a mounting plate made up and the nissan CAS mounted.
i think these are the 2 biggest issues, the others would be mounting all the nissan sensors on and in the alfa engine, but that shouldnt posse a problem and can i know it can be done, afm can be mounted easly, a custom plenum will be made allowing the use of the nissan fuel injectors and throttle body, tps and iac and the temp sensor can be made to fit the TS wherether it be by tapping existing hole or making adapter.
does anyone have any suggestions or advice as to how it can be made to work? or reasons why it can? its still all ideas and would be a good project. anyhelp / comments welcome
cheers, Brad
cheers, Brad
