1 - 10 of 10 Posts
1984 Spider Veloce
Last week I noticed I was leaking coolant from the water pump. I ordered a new pump from Classic Alfa and replaced it, but noticed that the new pump has no bleeder valve on the top. So, I assume there is no issue and to just burp the system through the bleeder on the throttle body? Anything I should be worried about?
Thanks a ton for the help!
Ty
If you want you can drill and tap a 6mm hole where the bleed was on the original. Use a SS 6mm bolt (short) and aluminum washer to seal. Works fine.
You can also use a vacuum bleeder if you have an air compressor. They are ~$45 on Amazon and make bleeding the system a 10 minute job .
I simply fill the radiator leaving the cap off, open the heater valve, fire up the engine and let it run until it reaches full working temperature. I top it up as the air bubbles are burped and then fit the radiator cap.
I have one of those and they are da bomb. I bought it because I have a car that specifically requires it, but it works great on the GTV and 101 Giulia too.
I know a lot of the older water pumps had the bleed screw but I haven't seen it on any of the replacement pumps. I think Alfa decided at some point that it was not really necessary.
1 - 10 of 10 Posts
