1 - 11 of 11 Posts
Hi all, I just added a Giulia Super to my garage. It joins a ‘59 Austin Healey Bug or Frog eye Sprit, ‘ 67 MGB GT and a ‘72 MGB. Along with my daily driver a 2020 Giulia TI.
The super is in fair to good shape, working through brake master, tune up and radiator flush. I have questions regarding the oil pressure. I just changed the oil 20w-50, same as my British cars, It is running at 20 - 30 at idle and would not go higher when engine rev’d. I have rebuilt engines before, but did not want to do it right away on this car. So the question is, since I am new, what is the most common cause to low oil pressure, bearings, pump or sending unit. The sending unit looks like a lot of fun to get to with engine installed. Thanks for your help in advance. Mike
That sending unit is a knuckle buster, for sure. I had oil pressure issues with my Super - pressure would drop as the engine warmed. My son-in-law and I decided to have the oil pump rebuilt and the O-ring that should have been between the pump and block in the sump. The pump rebuild did the job for me, although I think my gauge is another part of the problem - I have a second gauge under the hood, and it reads correctly.
Not sure if any of that will help.
It was very helpful. Would you say the oil pump and sending unit are the frequent sources of low oil pressure, unlike the MG’s and TR4 I have worked on low oil pressure primary reason is bad bearings. Also how did you hook up a second gauge to measure.
The second gauge is a direct reading gauge. It was already installed when I bought the car, and I'm not sure how they did it. Send me your email, and I'll take some photos and send them to you. I'm [email protected].
It looks like they put a fitting in an oil galley on the driver side of the engine - it's a bit odd.
Mike
I will relate my experience wherein the reading changed after removing the sender and cleaning out the tiny orifice w/ a needle or very small drill bit, don't recall exactly. Used carb cleaner too. Pressure indication went up, and was more in line with readings on a mechanical gauge installed temporarily.
Following your post closely because I, too am a recent Giulia Super owner and am fettling a few issues before it's ready for Prime Time, i.e.- MVD title transfer inspection.
Capp, That is what I am working on now is to get the car ready for MDV. So Capp how did you get the sender out? From on top or from below?
Actually, that was on a former car, a GTV, but same method applies. I accessed it with the air cleaner assembly removed and don't remember it being difficult, but it was a Spica car.
I happen to have a new sender in my hand and it appears that a stubby 17 mm open end will get it if you have the top part of the air cleaner off..... probably....maybe...you know.
Your older, possibly original sender may likely have a different hex- almost certainly smaller.
Thank you. I need to take off the rest of the air cleaner and should be able to access. It is tight, but doable.
mike
1 - 11 of 11 Posts
