New Member - Alfa Romeo 1973 2000GTV RHD
1021 Views 10 Replies 5 Participants Last post by  PSk
Hi all,
I am browsing AlfaBB for at least 3-4 years now (mostly when in trouble 😂), and i finally decided to join.
The current project is a 1973 2000 GTV as described in the title. The car ended up in my hands after my dad decided to park it for some years due to some mechanical issues he didn't bother fixing at the time. Thankfully it was parked in a garage, so the condition of the body overall is good but of course at some point the body work must be done. On the other hand, due to the years sitting, the mechanical condition was bad except from the engine itself. I had to revisit/fix all of the peripherals from carbs/ignition to clutch/brakes and everything else you can imagine 🙃. Most of the "job" was done by myself. I'm not a pro mechanic but a hobbyist.
Currently the car is at the stage where it needs minor interior fixes and finally to polish the beast.
Automotive parking light Tire Wheel Car Vehicle
Looking forward to interact,
Stelios (Cyprus)
Reactions: 2
1 - 11 of 11 Posts
Looks pretty good in the photo!
Thank you Pete!
That's a sweet ride! Welcome
Thank you DasherG :)
Hi Stelios,
I was passed a link to this thread by someone on the AO forum in the hope you may be able to help me as you appear to have a 4 post lift! I am restoring a RHD 1973 2000GTV and I'm currently installing all new brake & clutch hydraulic pipes, but all the pipework I removed had been quite crudely done (not as it left the factory). Is there any chance you could take some photos of the underside of your car so I can see the correct routing of the pipe runs, especially under the floor pan where the master cylinders are mounted?
Andy
Hi Stelios,
Andy
i have a series 2 1750 RHD on the hoist t the moment. i think the brakes are all the same.
Reactions: 1
(y) brilliant, any pictures would highly appreciated as I am in a bit of a rut at the moment. I can't make any of the pipes the pipes that run from the master cylinders to the servos and reservoirs fit....way too short 🤬. I should of made my own instead of buying a ready made kit.
Hi Stelios,
Andy
Hi Andy, if needed i can take some pictures to help as well. I will need couple of days though since i need to raise the car.
p.s: The 4 post lift is not my own, unfortunately. :LOL:
Kind Regards,
Stelios
Thanks Stelios, that would be much appreciated....i'd kill for a lift like that instead of rolling around on my garage floor!
Deepblue74, these cars left the factory with a birds nest of brake pipes crudely running under the car ... sorry. Nothing beautiful about it
1 - 11 of 11 Posts
