Anyone needing a new distributor or maybe a bit better performance from a 2600 engine follow this link (Also for 4 pot Alfa)
Link Alfa Romeo
Or there is a used Marelli on Ebay - Item 110213900049 - $150
123\ALFA 2600
Price: €299.00
Availability: Op voorraad / In stock
Add to Cart
The 123\ALFA 2600 is designed for 6 cylinders Alfa Romeo engines fitted with a Marelli S93A distributor or a Bosch distributor no. 0 231 111 034.
Description
The 123\ALFA 2600 is designed for 6 cylinders Alfa Romeo engines fitted with a Marelli S93A distributor or a Bosch distributor no. 0 231 111 034. No more wear, no more replacement of points nor condensor EVER again. The advance is now electronically calculated : set it, and forget it! The unit offers a built-in LED for easy static timing and several different advance-curves, which can be selected by means of a little switch. This is a great feature for easy fine-tuning your engine!
It also offers:
- automatic dwell
- spark balancing
- automatic power-cut after 1 second
- etc. etc.
Note: Although used coils all look alike, they should be viewed with suspicion since one cannot tell from the outside whether, and how often they were exposed to overheating in the past. Installing the 123 Ignition system will ensure that the coil will never be overheated again in future. We recommend the Bosch Blue Coil.
Link Alfa Romeo
123\ALFA 2600
Price: €299.00
Add to Cart
Description
It also offers:
- automatic dwell
- spark balancing
- etc. etc.
