........1996 ford.......mustang 4.6 liter.. the 6 cly cars tach only went to 7k.. wanted to look more stock so 4.6 motor tach goe's to 8k...as a test set up everything worked.. except the fuel sender.. speedo was easy to do, just stuffed in a electronic sender from my cable sender, the tach was done by ' tach - adapt ' water oil pressure was with ford senders , that worked well with the stock fittings
