1 - 17 of 17 Posts
Hey i recently bought a 91 alfa romeo spider with 5 speed tranny. it has 34k miles and from what i can tell mechanically sound. it does have a lot of rust which i plan on taking care of what i can.
For now i need to figure out how i can get the speedometer and odometer to work. i read i could try removing it and checking out for corosion and see if the line to the motor is nice and tight.
What would be the course of action to take before i start removing the trim and is there a good diy guide on removing it because from what i can tell id have to remove quite a bit to get.
Ill try and post some picture soon.
Is there a place where i can get different trim pieces? right now im looking to do something about the rust under the rear taillights i have a pretty nasty hole.
If you do need to remove the speedo, below is a good writeup.
http://www.alfabb.com/bb/forums/spi...ing-speedometer-tachometer-91-94-spiders.html
Sometimes the motors go bad or the solder joints to the pins on the board that go into the speedo fail. However, an unfortunately common failure mode is for the electronic speedometer sender to conk out. There's a cable that runs from the transmission to the sender, and then the sender sends pulses to the speedometer. On the 91-94 Spiders the sender is mounted underneath the car near the exhaust downtubes and I think it just tends to get baked by the heat.
Well, there's a three wire connector in the engine bay you can try cleaning. Should be near the brake MC. It's black, pink-white, and something else I think.
inop speedo/odo
There is also a small plastic gear inside the speedo which can turn to dust. On my Volvo 850 I found several vendors online selling the gear so I bought one and put it in myself. On the Alfa I couldn't, I was just about to send it off to Palo Alto Speedo shop as they said they could repair it, when the opportunity to purchase a whole instrument cluster came by so I did that instead.
I'm having a similar problem- my tach, backup lights, heater blower, oil pressure gauge, and fuel gauge all stopped working since I did my clutch replacement. I think I made a short in the wiring around the gear shift. My #7 fuse pops immediately on key turn. My speedo works fine though... Not sure if this will help you, but good luck.
Discussion Starter · #11 ·
i took it apart and tried to see what was wrong with it yet didnt help. i tried to clean out the 3 wire connector too it still didnt help. what would be the next step?
does anyone know if i could just put after market gauges?
Why shore you could....but don't expect to win any concours prizes with aftermarket gauges. :p
Besides, with aftermarket gauges you might gain some accuracy...and that would put you in an exclusive club within the Alfa community...
(Sorry, couldn't help myself) Good luck with the project. You have actually found a very good resource for assistance on your car. And before anybody else interjects.... We LOVE pictures!!!
Did you check the fuses? It happens to me on occasion.
If your looking to replace, these look really good to me and not too difficult to install.
tach - speedo replacement
Good luck,
Vin
Discussion Starter · #17 ·
it was the fuse it was corroded but was still working yet after i cleaned it i guess it let enough voltage pass for speedo and tach to work but now my fuel gauge isnt working yet before this whole procedure it worked somewhat. it used to jump around like crazy when i was driving but when i just started it up it was reading right as far as i know. now it doesnt move at all
1 - 17 of 17 Posts
