So it's obvious(maybe not) that I have a leak of some sort. I've refilled the brake reservoir twice in the last week so something's up. Brakes work fine with no sponginess, it's just the warning light goes off and then time to refill. When I look at the reservoir it's the rearward "compartment" that is low. Not sure if that means the front or rear brakes or neither.
I do not see any wetness in the engine bay, and no obvious drips on the driveway. So where would you suggest I start my quest to see what's going on?
My GTV is a 1970 so it has the single brake booster.
I'd pull the booster hose and check in the booster. You are likely leaking out the back of the MC into the booster, in which case you need a new MC.
