1 - 9 of 9 Posts
I need to know the thickness of the mounting bosses on the axle tube , were the brake backing plate clamps on to .. thanks.. spider type axle.
Pretty sure this isn't what you want.. But until you get what you need here's a picture :)
This varies a bit, or at least the depth of the wheel bearing pockets might differ. This may be limited to Giulia's. I used a 2L center grafted into Giulia 1600 tubes using 2L half shafts and found the bearings 2mm too narrow. There is a simple solution. Previously I had a GTA LS 5:12 with GTA shafts in a pair of Giulia tubes without the bearing issue. I did not bother measuring GTA bearings, Giulia 1600 bearings or 2L shaft bearings, just made it work.
It'll be Ok. They've been upside down so long they won't notice.
craig, perfect... what cookies do you want:)
Iced vovo's please... best biscuit there ever was !!
(....and now that I've gone and said that I may just have to whip down the shops and get some... Bugger, put the kettle on, back in a mo)
MMMmmmmm yum Iced VoVo do you dunk scrape the top with your teeth or just ho in
1 - 9 of 9 Posts
