I'm restoring a '74 Spider and have what appears to be an electrical problem with the fuel pump. Here are the symptoms: The car starts fine, the fuel pressure light goes out immediately like it's supposed to for the Spica but occasionally and sporadically while I'm driving the car the fuel pressure light comes back on and the fuel pump quits working. The car continues to run just fine, I assume because the Spica system pulls fuel even though the fuel pumps stops. It's when I shut the car off when this happens that I have the problem. When I try to restart the car, the fuel pressure light stays on, the fuel pump does not engage and the car will not restart. There is a buzzing sound behind the generator/alternator light on the tachometer. Eventually (sometimes days later), when I repeatedly try to start the car, the buzzer stops, the fuel pump starts, the fuel pressure light goes out immediately and the car starts right up. It's not the fuel pump. I installed a new one and the same problem persists. Fuel filters are new and the tank and fuel lines are clean. Very frustrating problem on an otherwise great car. Any ideas about how I can fix my problem?
