Howdy All.
The time has come for me to part with my 73 Spider. I no longer have time or room for it and I don't want to see it deteriorate and get banged up in my crowded garage.
I’m hoping I could get some insight and opinions on what a fair asking price would be for my car. I purchased the car from the original owner's son some 19 or so years ago. He gave me a folder full of service records so I know his dad took good care of the car before his son got his hands on it. I purchased the car with body damage and in need of some TLC.
I spent a ton of time working on this car over the years(good therapy). I replaced most of the things that one would expect to go bad with one of these lovely cars. Most of the mechanical refurbishing and parts renewal on the list below were done at the beginning of covid when I had some extra time on my hands.
It's a southern California car with current registration and located in the Los Angeles area. I listed both the good and not so good so that it would hopefully represent an honest assessment of the car. I’m sure I’m missing something but it’s a good starting point.
I honestly don’t know how much to ask for it and I’m not sure I’m interested in an auction site. I hope to get a sense of a fair value and I’ll put it for sale once I assess the input.
I really appreciate any input or advice.
The Good Stuff:
Rust free
Purchased from original owners son
Repainted around 10 or so years ago, looks nice but has a few issues. Presents well except for the nose damage(thanks to my wife).
New rubber everywhere (doors, all windows, trunk, hood, etc)
Side makers shaved (plates welded. Wiring still exists)
71 front bumpers plus 73 spare parts
New centerline springs
New Koni shocks
New read end bump stops
New rear end limit straps
Neoprene bushings installed in rear end
Front suspension refresh
New sway bar bushings
Rebuilt brakes calipers
Stainless brake lines
New wheel bearings and seals
Newer brake rotors
New brake pads
New brake master cylinder
New brake booster
New clutch master cylinder
New clutch slave cylinder
New aluminum spica linkage ends
Newish distributor cap, rotor, plugs and wires
All fuel lines replaced
Refurbished ZF steering box (leaky Burman steering box included)
Electric fan upgrade(original parts included)
All heater hoses replaced
New thermostat and gaskets
New Valve cover gasket and rubber plugs
Valve cover painted with wrinkle finish paint(looks sharp)
Refurbished rear end (cleaned, painted and replaced all the seals and bearings)
Redline used on rear and trans
Tires are in great shape, look new but installed several years ago
Original rubber mats
Bluetooth sound system with custom plate(no modifications to dash)
Insolation on floor board
Rubberized asphalt sound deadening tiles on floorboard and firewall
Wheel alignment completed
Newer battery
Custom exhaust, from manifold to the back
Reviewed and cleaned all wiring
New trunk carpet
Jack repainted
Lots of misc parts, hardware and thingies included
Presents well, a good fun driver
Most of the things that can break or wear out on you have been replaced.
The Not so good stuff:
Salvage title (car had body damage, too expensive for insurance 20 years ago when I bought it)
Front cone damage, my wife backed into the car in the driveway(argh! After all this work!)
A few chips throughout (thanks kids)
Bumper trim need some polishing and TLC
2nd gear grind, not terrible just need to ease it in
Needs a new top, the cloth has areas of wear and the plastic window is cloudy and cracked(it may be repairable, I don't know. The frame is in good working order.
Thermostatic actuator needs to be rebuilt or replaced (currently adjusted for full warm up, it doesn’t expand long enough)
Rear bumper is pushed in a bit, easy to straighten out. Never bothered to install it, , I like the look without it.
Heater coil leaks, not sure if it's the connectors or the coil itself. It’s currently bypassed
Heater fan is not working. It was working before the leak. Electrical circuit works. Most likely rusted so it won’t spin. Should be easy to fix when you get to it.
Needs little finishing touches throughout the interior
I have a lot more work in progress pictures
The Good Stuff:
Rust free
New Koni shocks
Newer brake rotors
New brake pads
New brake booster
Newer battery
New trunk carpet
Jack repainted
