Hi,
Just rebuilt a 33 16v motor to go in my 76 Sud. The factory manual is quite ambiguous on how to properly set up the cams and belts. There are two sets of marks on the cogs, a small arrow on each, and either an I or a double II on each set.
I have the engine at TDC, so what set of marks should line up when the belts are fully tightened? The "I's" or the arrows? The factory manual shows either depending on what page you are on, which makes it dangerously frustrating.
Also is there any second party workshop manual available that might cover this subject more clearly?
Thanks, Ted
Thanks, Ted
