1 - 5 of 5 Posts
I can not find this in the schematic provided by Papajam (thank you!)
It is located under the glove box and is a (or at least what I pulled out) 1/8 amp fuse.
Any ideas what it is?
If I knew what the two switches were I may be able to find it. I can trace the wire colors on the schematic but need #3 ..#2's just aren't doing it anymore lol
My EXH Temp light stays lit..that could be it. Can't find a 1/8 amp fuse yet...will QUICKLY try some gum wrapper (don't think there is such a thing anymore) or a spot of aluminum foil to see if that turns the light off.
Well perhaps I won't... checking what you stated it seems to be the fuse for the EXH Light which is my issue but I read if it is not a 3AG 1/8 amp fast blow fuse it could cause damage. Auto parts stores don't carry it..perhaps my favorite 'manly' Tractor Supply store will have it :) They have everything you can't find at Lowes and Home Depot.
Putting in the wrong fuse, or jumping it with foil, may end in tears. Why not just disconnect the wire connector instead?
EDIT: I wrote the following in another thread not long ago;
That device is part of the catalytic converter over temperature warning system.
tech service bulletin 05.05 dated 10/78 says the fuse in the warning device is a Littlefuse brand 3/2 3AG 1/8 amp fast blow type.
Do NOT use a BUSS brand AGC 1/8 amp which is a slow blow type.
1 - 5 of 5 Posts
